Pulse Wipers Question
Old Oct 27, 2007 | 08:01 AM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Transmission: 5spd Auto /700R
Hey Guys, My pulse, or delay, wipers stopped working on my 87 IROC. They still work on "low" and "high" just no delay function. So here's the question, is the delay function controlled by a relay in the wiper motor itself? Or is it in the switch on the steering collum?
Geno.
Old Oct 27, 2007 | 10:19 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Pulse Wipers Question
BOTH,......... More than likely the problem is the result of the internals under the wiper motor "cover" .
Old Nov 12, 2007 | 09:43 AM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Okay, I replaced the winshield washer motor in the wiper motor assembly, but still no washer or pulse wipers, just high and low. I've been reading posts from other members with this same problem and many have said that the "pulse board" is the same on most late model GM cars with the delay wipers. So, how do I gain access to the pulse board? Where is it located?
Old Nov 12, 2007 | 09:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Under the motor cover.
Old Nov 13, 2007 | 01:47 PM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Okay, If I go hunting through the wreck yards looking for another pulse board what is the year spead of cars that would use the same board? And did all the GM cars with pulse wipers use the same board? In other words, could I find one in say, a Buick or Cadillac?
Old Nov 16, 2007 | 12:22 PM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Got your message, Jason. Thanks.
Geno.
Old Nov 27, 2007 | 11:25 PM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Okay, I swapped out the wiper motor assembly complete with the wiper motor cover and new washer pump. I got it from Hawks ThirdGen for 35 bucks. The only change is that when I press the washer tab on the turn signal lever the wipers move where before they did not. Still no pulse. The wiper motor cover swap seems to have cured all the problems the other guys have posted. This has got me stumped.
Any ideas?
Old Nov 27, 2007 | 11:47 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Are you sure you got a pulse cover from Hawks?
Old Nov 28, 2007 | 12:00 AM
Geno.'s Avatar
Car: 1987 IROC Z28
Engine: 305/ 5.0
Well, thats what I asked them for. I spoke with them at length about my problem and I made sure they knew I wanted a pulse wiper motor assembly before I ordered. It's visually identical to the one I removed. But, I didn't see a part number on either one of the PC boards. How else would I know?
____________________________________________________________________
**UpDate**
I went to the wrecking yard today to hunt for some wiper motor covers. I found one but it was soaked in water so it may not work. But I found out that the difference between pulse wipers and the two speed wipers is that there is no P/C board under the motor cover for the two speed wipers. Now I'm sure that some of you guys are saying "Duh, yeah" right now but before this I'd never opened one of those units up to look inside. And I've been a motor head since the 1970's. But if I didn't know then I'm sure there are others. Maybe this will help them out.
Frozer!!!
Jan 19, 2024 04:55 PM
siberian3rdgen
Interior Parts Wanted
Aug 31, 2015 09:37 PM
Randomtask2
Aug 26, 2015 03:34 PM
redmaroz
Aug 16, 2015 11:40 PM
slade5612
Aug 11, 2015 07:19 PM
