Gauge Light Replacements
Old Nov 10, 2007 | 04:43 PM
Priddin's Avatar
Car: 1991 Camaro RS
Engine: 3.1L v6
ok all i did wasand and i still havent been able to find anyone that says other wise. I have boughten all the 194 leds i need for my gauge cluster and when i took mine out the bulbs are soldered in the socket, is there anyway to break the solder and put the leds in them? or do i need to buy new sockets that have no bulb in them at all, and if so i went to napa and asked for sockets and the guy said that you cant put new bulbs in the sockets. he said it was "impossible" and apparently "no one on There knows what they are talking about". exact words, so now that i have it all apart i thought i would ask? is it possible to remove the bulbs and replace them or do i need to buy new sockets and from where.
Old Nov 10, 2007 | 07:44 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Gauge Light Replacements
I used to have a bag of those sockets, junk yard or place an ad I am sure someone has a few lying around. All the ones I have ever seen or owned, the bulbs just pull out.
Old Nov 10, 2007 | 08:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Me too.
JamesC
Old Nov 10, 2007 | 08:44 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Same here, any possiblities in getting a soldering tool in there to at least loosen the solder and just pull it out one lead at a time???
Old Nov 10, 2007 | 09:34 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I was able to acquire some of those sockets at NAPA quite a while back. The whole assembly (light and socket) is part # PC194 and the bulb is soldered in the socket. I have since found other sockets at the local junkyard and stuffed them in my pocket.
Old Nov 11, 2007 | 05:23 AM
JamesC's Avatar
If you're going to pull the cluster, you might as well take a look at the following link (I'd be surprised if your trip odometer was still working):
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Jan 2, 2009 | 10:41 PM
Rodbow's Avatar
I found the same situation on my '93 Chevy G20 after buying the replacement 194s. Took em back to Advance Auto and the guy said he couldn't get the "entire asm". He said that after cutting his thumb on the glass frags years before, he just bent the replacement bulb wires over the outside edges of the "entire asm" socket to complete the circuit. I've done this just now on the bench but haven't tried to see if it will burn yet.
Old Jan 3, 2009 | 03:28 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
http://www.superbrightleds.com/instrument.html
Old Mar 16, 2009 | 10:28 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Originally Posted by paulo57509
How do you like the LED's......are they worth it? I'd like to replace all of my lights.
Old Mar 16, 2009 | 10:42 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
just do a WTB gauge bulb sockets in the want to buy section
i also think i have seen some at one of the auto parts stores
Old Mar 17, 2009 | 06:05 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
I have the same problem...I bought all the replacement bulbs at the zone ($25) and found that the origionals are soldered into the sockets. What a pain this is going to be! I tried NAPA but no luck
Old Mar 17, 2009 | 07:43 PM
89RS_82Z's Avatar
oh yea i should of mentioned 90 and above had sodered in gauge lights sorry i should of read my own post
but you can use the old replacable bulb style, i did that to my satty when a few blew out
Old Mar 17, 2009 | 07:48 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
They have them at most parts stores, check the "Help" section, or maybe it was in the electrical section. Somewhere on here, I posted the brand/part # I had bought, but that was a few years ago.
Ask the guy at the counter for "194 base" or "194 Socket" for GM dash's
Old Mar 17, 2009 | 07:59 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
I just got it done....it took about an hour and a half to pick them apart and replace...but they work! I didn't bother with the turn signal cause they just didn't want to come out...oh well
Old May 28, 2009 | 05:05 PM
tgscooter's Avatar
Car: 1985 Pontiac Trans Am
Engine: 5.7L LS1 FI
Axle/Gears: 3.23 factory 9 bolt
I am planning on replacing mine soon. But I was hoping to order them in advance online. Anyone know how many 194s are in the entire cluster? I have the 140MPH/8k cluster, if that makes a difference. Thanks
Old May 28, 2009 | 08:53 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
can't remember which ones are the 194's....but if they're the bigger ones, I would get at least 10 - 12 of them....that way you have more if you need 'em and you wont have to pay shipping again.
Old Dec 3, 2009 | 06:19 PM
cyberleader's Avatar
Car: 2002 Z28
Engine: 5.7 Stock
Axle/Gears: Stock
i just replaced my 91's with superbrightleds and there was no soldering whatsoever... everything just twisted out... couldn't have been easier!!!
Old Dec 3, 2009 | 08:55 PM
JamesC's Avatar
http://www.macewenmotorsports.com/howmabudoine.html
JamesC
Old Dec 3, 2009 | 09:06 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
There are two types of lights that are the same size and fit. I believe #168 is for interior, and #194 is for the exterior of the car(ex. parking lights, side markers, etc....). And it IS important to get the right one, because one of the lights heats up much more then the other!!!.........I could be wrong but, #194 should be the hotter light! And you could run the risk of melting your gauge cluster/panel.
Old May 14, 2010 | 04:12 PM
benoit1237's Avatar
I have a question. I'm new here so gentle ok. I replaced all my bulbs cuz most were burnt out. I havean 86' with a 305 and a 145mph speedo. My issue is that my dumbass removed all the old bulbs at once instead of replacing one at a time. Now my turn signal lights saty on and other just don't light. Or light up when starting the car than turn off. How on earth ca I tell what order to put them back in place so the right ones go into the right socket? Thanks for any help.
Old May 14, 2010 | 04:26 PM
Car: 87 T-Top GTA
Like I said, all dash/gauge lights should be 168's. If a smaller light was needed, then it would also have a smaller socket!
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Omega
Aug 10, 2015 12:46 PM
