Turn signel
Car: 89 irocz
Axle/Gears: 373
Turn signel
ok one day im driving down the street and put on my right blinker and it sticks the light just stays on so i parked and checked to see what was going on my front blinker stays solid and my back on isnt doing anything so i figure its just the bulb but befor i changed it it started to work agean. And then so i just figured that every thing is probably ok now but then the next day i go out and it just stayed solid. so i have changed the bulb and it still just decides to work when it wants to somdays it does some days it doesnt? i have know idea that is going on but its really starting to **** me the F*** off please can some one help me
Car: 86 IROC-Z
Engine: 305 V8 carb'd
Re: Turn signel
Mine was doing the same thing, they would just stick in the on position, but my front marker light was blown & after I changed it , it all started working again. Maybe the wiring???
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Turn signel
mine was doing the same thing, but mine was the driver side...for me i notices that little wire that was added to the front parking/turn signal bulb was shot, it would move and stop making contact, i pulled it out of the socket and tryed bending it out and it broke, but i bent what was left so it would make contact and it's worked perfectly ever since. When you turn on your parking lights, jiggle that extra little wire that goes into that socket and see if it you get the problems you were experienceing.
Anyone know where to get replacement plug for that socket???
Re: Turn signel
Just a thought, who knows....
They're usually hanging on cards out in the open in the electrical aisle.
Car: 89 irocz
Axle/Gears: 373
Re: Turn signel
thanks but its somthing with the back turn signel cuz it doesnt light up so i got a new socket form Auto Zone and it sill doesnt work so i have no cule the light sticks and the front one lights up but the back one does nothing? i will let yall all know what happens because i will be getting it fixed soon
83 Crossfire TA
Sep 8, 2015 12:06 PM
