HELP! Car wont crank, Have No Power
Old Nov 14, 2007 | 06:40 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Got in my car after work today and turned the key to start the car. Nothing happened. I have no lights no nothing. Battery is good, I put in a new one just to see and still nothing. I checked to see if I had power to the starter from the battery I have 12.65 volts. Checked all 3 fusable links at the starter nut and they all have 12.65 volts. I did not check to see if the fusable links are blown since it was 6:20pm and I had a little led light so I cant see very much. I have the hanes repair manual and I am looking at the starting and charging system wiring diagram and I am only seeing one fusiable link shown. What are the other 2 hoked up too. I am not seeing them on any diagram in the book. Any help would be great
Old Nov 29, 2007 | 08:33 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
Re: HELP! Car wont crank, Have No Power
hey did you find out what is wrong with your car its sounds alot like my problem thanks
Old Nov 29, 2007 | 08:54 PM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
You check the ground at the solenoid? One of my other cars and a work truck I used to drive had the same problem one day, turns out the ground was rotten/corroded to the point where it wouldn't even "click click click".
Could try tapping the side of the starter while someone else turns it over, tap the casing with moderate effort and tap the solenoid if you can reach it very lightly. A bit crude but could let you know where the problem is, solenoids are sometimes the culprit.
Old Nov 29, 2007 | 09:22 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
had this same problem on my bro's firebird and it was the solenoid...
Old Nov 30, 2007 | 05:38 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Jake,
Check both sides of the fusible links. Start at the battery and work your way forward. Use diagram below to trace wires. The fusible link feeding the ignition switch is suspect.
</IMG>
Copyright © 2002 Delmar, All Rights Reserved.
Old Nov 30, 2007 | 09:44 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
No light, no nothing?
- Turn headlights on. Do they light up? No? Go measure the battery (post) again (with the headlight switch ON). If it shows 12+, cool.
- Measure voltage on the CABLE from the battery. If it shows close to 0, it's a battery terminal connection. Been there.
- If the cable has 12V, go measure the starter solenoid again. 12V on the post? No? Bad battery cable or connection.
- Now measure voltage on the orange wires, not the post. 0? Bad connection somewhere on the post.
- If you have 12V on the orange wires, wiggle them. Do the heglights light up/flicker? Bad fusible links.
- Go inside and pull let's say the courtesy fuse. Measure voltage no the metal clips inside. Nothing? Must be a bad fusible link on the orange wires.
Hope this helps.
Lou
Old Nov 30, 2007 | 10:42 PM
Found The problem. The batt plus terminal on the starter soliniod had broken or loosened up to a point that power could not flow. Fixed that by putting in a new starter soiliniod. Went to start my car and I hear a whine. The starter spun up but the starter drive did not engage into the flywheel. Needless to say I was not happy. After all that work I had to replace the starter anyways. Now all I have to do to it befrore I put it away for storage is fix the fuel leak from my rusty steel lines
Old Dec 1, 2007 | 11:01 AM
BigBadLou's Avatar
Engine: TPI
Glad you found it! Good job.
Lou
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
Brcharrelson
Aug 26, 2015 07:47 PM
TheExaminer
Aug 26, 2015 04:59 PM
novaderrik
Aug 10, 2015 12:44 PM
