VSS/no computer
Old Nov 22, 2007 | 07:14 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
VSS/no computer
basically, Is it possible? my car does not have a computer and currently I have a cable driven speedometer. I need to convert it to the wire kind before I swap to a T-56. also whats the best way to convert the signal from the T56 to the 3rd gen gauge
Old Nov 22, 2007 | 07:21 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: VSS/no computer
try this place.transmissioncenter.net
good luck man!
Old Nov 23, 2007 | 08:36 PM
C.M.Jones's Avatar
Re: VSS/no computer
bump
Old Dec 9, 2007 | 04:23 PM
C.M.Jones's Avatar
Re: VSS/no computer
bump again? ppl are putting them in much older vehicles how do THEY get over the problem
Old Dec 9, 2007 | 07:32 PM
Re: VSS/no computer
well,since this place didn't work for you (www.tansmissioncenter.net)
maybe try a search on here. I just typed in t-56 tranny swap and found alot of info. Hope this helps
Old Dec 9, 2007 | 07:56 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: VSS/no computer
You can use something similar to this...
http://www.dakotadigital.com/index.c...rod/prd109.htm
Old Dec 9, 2007 | 09:23 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: VSS/no computer
If your not running a computer then you just need to change the tailshaft housing to a cable driven speedo.
Old Dec 11, 2007 | 12:13 AM
C.M.Jones's Avatar
Re: VSS/no computer
you cant do that with a T56
none of them were cable driven
Old Dec 11, 2007 | 01:06 AM
Al Hasse's Avatar
Re: VSS/no computer
They can be converted, but I understand it's pretty spendy
http://www.jagsthatrun.com/Pages/Par...pp6-3_6-4.html
Old Dec 11, 2007 | 07:00 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: VSS/no computer
there is also this option
http://www.gaugeguys.com/cablex.htm
Old Dec 11, 2007 | 01:09 PM
C.M.Jones's Avatar
Re: VSS/no computer
yeah that an option and one I might have to go with but, 300 BUCK!!! they want too much for it. someone needs to compete with them
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
