VATS key
Old Nov 30, 2007 | 11:33 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
VATS key
im replacing the steering column on my car the replacement column comes with a key do i have to use my 1st key still or can i just plug n play with the new key?
Old Nov 30, 2007 | 11:44 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: VATS key
I believe you still need the first key
Old Nov 30, 2007 | 11:58 PM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
Re: VATS key
Did it come with the key with the chip? If not then you will have to use your old key switch,it will have 2 wires,orange and white,you can use a key switch with out the chip,if you get a resistor that has the same ohms as you old key,and just insert it in the black plug,with orange and white wires under dash,then when you go to start car,the VATS system will reconize the ohms.
That way you can use a 17 doller key switch,instead of the 50 doller key switch.Touch positive to one side and negitave to the other side of the key,with a ohm meter,measure ohms,then go to radio shack and get a few resisers,they are real cheap, with in 1 ohms of the original key and insert it in the wire I told you about,resister is under 50 cents
If your key measure 3 ohms,try to get a 3 ohm resister,if you can not find one ,get a 2 to 2 1/2 ohm resister and so on. I did this to my 90 model formula ,when the key switch messed up,car never failed to start,the VATS system thought it had the correct key,when I had the key with no chip.
hope that helps!!!
Old Dec 2, 2007 | 12:47 PM
w01fm4n's Avatar
Car: 1991 Chevy Camaro RS
Engine: 305/5.0 Liter V8
Transmission: Borg-Warner T-5
Axle/Gears: Stock... Not Sure Yet
Re: VATS key
Good Idea but i found the Key's Cheap on Ebay uncut, just measure your OHM Resistants and make sure you buy the correct replacement, and i had a local locksmith cut em for cheap....
Old Dec 2, 2007 | 01:06 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: VATS key
i personally would want to keep my Vats working only with the key and not bypassed. a friend had his camaro stolen and his VATS were turned off. he got lucky and got his car back, shortly after he returned his VATS to correct working order.
measure the key that came with the coulm, if its the same as your orig key then your ok, no need to spend any cash. if its diff then take the old key and tell them you need one cut to this key but match the value to the orig key and your done. as mentioned by one person, you can get a key off the bay if you know your value.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
