Best way to connect wires
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
I love to solder, but when trying to connect more than 3 wires it gets a little hairy.
I have a 4-gauge wire that I would like to connect to 7 or 8 12-gauge wires. What's the best way to do this?
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: Best way to connect wires
You can probably get a distribution block somewhere. They won't have 8 outputs but you should be able to find something or use two if you have to. Not too helpful, but that's all I got!
Transmission: WC T5
Thanks for the help. I found that practically all distribution blocks are geared for 8-gauge amp wires. I don't mind piggybacking 2, but so far the only choice I have is to try to fit a 12-gauge wire into an 8-gauge hole. I know it's possible but I would prefer not to rig it.
db057
Aug 11, 2015 10:11 PM
