Wipers only going up about 2 inches
Old Jan 8, 2008 | 02:30 PM
92rs25thproject's Avatar
Car: 92 rs 25th anniversay edition
Axle/Gears: 3:49 stock
I recently swapped out my broken 92 tilt column and replaced it with a 94 and now for some reason when I turn on my windshield wipers, they only go up and down about 2 inches and they only work in the full on position, no delay, but when I hit the wiper juicer they go all the way up and down like normal. Also the high beam dimmer doesnt work so I only have low beams. COuld it be something defective with the switch, or momst likely a problem in the wiring to the system. I noticed that the wiper motor appears to be jamming when I turn them on high and you can hear and watch the reciprocating motion but it clunks when it gets to a certain point.
Old Jan 8, 2008 | 02:49 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Wipers only going up about 2 inches
your wiring is off. check the colors at the connection at the bottom of the column
Old Jan 8, 2008 | 04:29 PM
figurd it had something to do with the wiring seeing how its a 94 column in a 92 car. OK I checked the harnesses and heres how it lays out... on the '92 port the wires are M-pink with black stripe L-Grey K- Black J- Grey with black stripe. on the 94 column it goes M-Pink L-grey K-blue J-Black any ideas on how to bypass/rewire that?
Old Jan 8, 2008 | 04:37 PM
ryan91rs's Avatar
Transmission: 4L60
ya, should have got a different column but we all live and learn
Old Jan 10, 2008 | 10:00 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Anyone else have any helpful information on this? Mine is doing the same thing after replacing the section of my steering colum with one out of a '95 T/A so I could have the keylock for a manual seeing that the manual 3rd gen columns are few and far inbetween to find.
Old Jan 16, 2008 | 06:17 AM
Klortho's Avatar
Car: 1987 GTA
anyone?
Old Feb 10, 2008 | 01:20 AM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
I have an 89 that had similar problems. I had power to the multi-function switch in the column, but sometimes minimal out or even none. I could direct wire power to the wiper motor and would work fine. Replaced the switch and worked fine. Dunno if that helps, but a route to check out.
Old Feb 11, 2008 | 08:23 AM
Stephen's Avatar
Car: 87 GTA
I dunno if switching the wire colors to match, would be as simple as that. But where the wire plugs in, you can use a pick/probe (tiny nail) to release the wire end, pull them out, then plug them back in, to match wire color to wire color. So when the 2 plugs are reconnected, gray to gray, black to black, etc.
I put 4th gen mirrors on my GTA, and the plugs were identical, but the wires didn't match up. Up = up, down =down, but left= right and right = left. So I switched 2 wires, and all was good.
Old Feb 11, 2008 | 11:45 AM
That would work great but the wire colors on my new column ( 94 ) dont match the colors of the harness on the car ( 92 ) So the only way I could see fixing the problem is to check the manual to see which two wires are for the wiper and which 2 are for the CC in my book and look while im at Autozone ( open one ) and look for a 94 then splice em together with heatshrink and solder
Old Feb 11, 2008 | 12:12 PM
Stephen's Avatar
Car: 87 GTA
Even if the colors don't match up, you could still move the wires, and make it all work. The wire colors would just be different, but there'd be no cutting and splicing.
Old Feb 11, 2008 | 06:19 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
After looking at the wiring diagrams for both 3rd and 4th gen's the only way to make it work is to install the 3rd gen switch. The power for the park feature comes from the wiper switch in the 3rd gen. But is wired seperate from the switch on the 4th gen. If you want the diagrams I can send them to you. Change a wiper switch is not to hard just time consuming and lots of tools. Mike
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Oct 1, 2015 11:24 AM
