where is the turn signal flasher on my 1988 GTA ?
Old Jan 13, 2008 | 02:00 PM
smash attack's Avatar
Car: 1988 GTA
Engine: 5.7 TPI
Where is the turn signal flasher on my 1988 GTA ? someone said that could be the problem with my turns not working. Is it in the area above my convenience center inside the dash as mentioned on this forum? There are TWO of these in there ? One is for the turns and one is for the emergency flashers ? Where do I buy a replacement ?... autozone, etc ? Does anyone have a PHOTO of the turn signal flasher ?
** symptom**: no turn signals. when I move the signal lever up and down manually they will light, but no flash thats it.
thanks
smash
Old Jan 13, 2008 | 06:48 PM
sfusco3's Avatar
Car: 91 firebird, 89 trans am GTA
Re: where is the turn signal flasher on my 1988 GTA ?
It does seem like the flasher. It's a small circle metal can thing that hangs under the driver side of the dash. You can get it at any auto parts store.
Old Jan 13, 2008 | 07:08 PM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
I would check your bulbs too. If one of your lights is out, the other one will light steadily, and your turn signal indicator on your dash will light steadily as well. No flashing, just illumination. Also could be the flasher.
Fronzizzle
Mar 18, 2019 08:29 PM
stalkier
Aug 21, 2015 01:54 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
