Tachometer Signal?
Old Jan 16, 2008 | 06:49 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Tachometer Signal?
Does anyone here happen to know what kind of a signal our tachometers use? Is it just a positive 12 volt square wave that has it's pulsewidth modulated based on engine rpm and how fast the ignition coil is discharging?
Old Jan 16, 2008 | 06:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Tachometer Signal?
The tach is connected to the coil primary, so it's FM not PWM.
Old Jan 16, 2008 | 06:57 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Alright, thats even better It is a 12 volt square wave correct?
Old Jan 16, 2008 | 06:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
12V give or take, but I wouldn't count on it necessarily being square.
Old Jan 16, 2008 | 07:09 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Yup, the tachometer wire (usually white) is connected to the coil's primary side, the groudning wire, not the pink power wire.
Hope this helps.
Lou
Old Jan 16, 2008 | 08:11 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Awesome! Just got my handy dandy 25 dollar Princess Auto tach working on the bench here.
Now to start generating the crazy AC sawtooth waveform my diesel's engine speed sensor puts out, and condition it to output the same 12 volt square signal I've built here with the 555 timer then calibrate it in such a way that I have a reliable tachometer setup on my diesel without having to worry about tapping into my alternator, or gluing stuff to various rotating components on my truck...
Thanks for your help guys!
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
thunder57
Nov 7, 2015 02:28 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lewandom
Oct 1, 2015 08:15 AM
