nordskog senders
Old Jan 23, 2008 | 11:14 AM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
nordskog senders
I was thinking of buying a nordskog dash for my camaro.
included in the kit are some senders made by nordskog ( temperature and oil pressure) only problem I see is. the sensors from nordkog are 1 or 2 wire sensors.
while the original gm sensors are 3 wire sensors.
anyone here installed nordskog sensors in place of there normal sensors ?
Old Jan 23, 2008 | 12:05 PM
SteelTownMadDog's Avatar
Re: nordskog senders
Not sure what model GM you're talking about but both my temp & oil senders are only 1 wire.
Old Jan 23, 2008 | 12:08 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
91 camaro RS
Old Jan 23, 2008 | 01:26 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
well if theyre both 1 wire senders and you have the corresponding gauges, why would it matter what they used to be? just rewire the temp/oil sending unit using one wire.
Old Jan 23, 2008 | 01:38 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
because the temp sensor also goes to the computer wich controls the fan. I dont want to stand in traffic figuring out that the computer doesnt get a tmp signal. making the fan not running and overheating my car.
would be the most expensive sensor ever.
Old Jan 25, 2008 | 02:57 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Im pretty sure you car has a Fan Switch also. The fan switch sends the temp to ECU and the Temp Sender goes to the gauge.
Old Jan 25, 2008 | 04:50 PM
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
and where would that temp sender be located on a V6 camaro since i just cant find the damn thing. do also note that hypertech or any other manufacturer doesnt offer any fanswitch for the V6 to lower the temp.
http://di1.shopping.com/images/di/4d...00x100-0-0.jpg looks like this
Old Jan 25, 2008 | 09:51 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
I could not answer that for you, I have a 350 in my RS. I would post in the V6 board for your answer. Sorry i can't help you any more
tommy z-28
Oct 6, 2015 10:58 PM
eustodp
Sep 20, 2015 05:09 PM
CatmanFS
Sep 19, 2015 09:00 AM
Ironhead38
Sep 7, 2015 02:26 PM
NBrehm
Aug 25, 2015 11:49 PM
