Cranking and Ignition issues...
Old Jan 30, 2008 | 10:35 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Ok, so i am attempting to start my 350. It's not high compression or anything, but when i turn the key, it turns over really slow. My battery has 13.4 volts and is rated to 820 CCA. I had it tested at the auto parts store and it tested good.
So basically i have a full battery, and slow cranking. Does that mean my starter is weak?
Old Jan 30, 2008 | 10:40 PM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
Re: Cranking and Ignition issues...
yup, time for a new starter, but first check your connections on the starter
Old Jan 30, 2008 | 10:53 PM
82Five-O's Avatar
Car: 82 Sport coupe
Crap.. I was hopin it wasn't that. Yeah, i've replaced the cables, and all that stuff, but it did no good. I appreciate it Spina.. Nice sig by the way!
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:40 AM
383cam
Sep 9, 2015 06:01 AM
