No dash or interior lights
Old Feb 7, 2008 | 09:11 PM
Deeder's Avatar
Car: 1991 Camaro
Engine: 377 Carbureted
Transmission: 700R4 w/ 3000 stall
Each time I turn on my headlights I blow the interior light fuse. Any ideas where to start. Thanks!!
Old Feb 7, 2008 | 09:18 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: No dash or interior lights
Start tracing wires, you have a knicked wire grounding out. I would start at the headlights and work my way back to the switch
Old Feb 7, 2008 | 09:19 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I would first check the cig. lighter.
Have you recently installed a new radio?If you have,recheck your stereo wiring!
Old Feb 7, 2008 | 09:28 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
yea if you accidentally grounded out the illumination wire of your cig lighter (rare on most models) or stereo that will blow everytime you turn on your headlights.
Old Feb 8, 2008 | 06:31 PM
Deeder's Avatar
Car: 1991 Camaro
Okay cig lighter may be the issue but would it still work if it did ground? I plugged in my cell phone charger to it and it worked so is that still a feasible cause??? I have been tracing wires and half the dash is torn apart and no signs of a ground power wire. Let me know what you guys think if the cig lighter would cause this and still work. Thanks a bunch
Old Feb 8, 2008 | 07:20 PM
does the fuse only pop when you turn the headlights on,or does it also pop when you turn the parking lights on.
Old Feb 8, 2008 | 07:54 PM
Deeder's Avatar
Car: 1991 Camaro
the fuse pops as soon as you turn on the parking lamps
Old Feb 8, 2008 | 08:28 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Pull the lamps, turn the switch on, and see what happens?
Old Feb 8, 2008 | 09:19 PM
Deeder's Avatar
Car: 1991 Camaro
BTW I have not performed any stereo mods or installed a new stereo, this problem happened "all of a sudden".
Old Feb 9, 2008 | 08:05 PM
Deeder's Avatar
Car: 1991 Camaro
Found the problem!!! I had a rodent guest who decided to infiltrate my console and build himself a nest out of my stereo wires. But I fixed it today, Thanks for the great ideas and direction!!
Old Feb 9, 2008 | 09:30 PM
Congrats! I hope you gave that rodent an eviction notice lol!
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
