toggle switch help
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
toggle switch help
how do you hook up a toggle switch with 3 pronges? also can i ground out the leds im installing to the ground on the switch? thanks
Car: 2000 SS, M6
Engine: Modified LS1
Re: toggle switch help
It depends what you need the switch to do.
The middle terminal is usually the common lead (B), an throwing the switch
up or down makes a path to either middle pole (B) to pole (A), or middle pole
(B) to pole (C).
As for the LED's, explain more about what you want them to do, and I
can draw up a diagram to wire the switch with the LEDs.
(B) to pole (C).
Engine: 355
(B) to pole (C).
(B) to pole (C).
Car: 2000 SS, M6
That' s not difficult at all.
The middle pole will be the voltage source, and then either outer pole
will have a diode connected to ground.
The cathode goes to ground, the anode will connect to the the switch
poles.
What other function is the switch going to produce besides lighting up
diodes? What are you controlling?
poles.
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
See if you get the idea from this thread.:
https://www.thirdgen.org/forums/elec...html?highlight=
The ground prong on the lighted switch is to be connected to car ground. The ground can then be branched off to the LED's.
Or you can do it the other way around and ground the LED's first and then branch a grounding wire over to the switch.
Or if the LED's are far away from the switch, ground them separately to save a long ground wire.
Randomtask2
Sep 10, 2015 08:37 AM
