88 IROC A/C clutch diode?
Old Mar 1, 2008 | 09:14 PM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
I have had a failure of the ESC module recently due to a failed A/C clutch diode...I think? At least all had been great until I decided to test the A/C, after about 5-10 sec's the ignition died. I have the wiring circuit info but no reference on the diode itself, can someone help with the diode ratings so I can find a part at the local electronics shop....is it a standard rectifier or surge suppressor?
Old Mar 3, 2008 | 11:31 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: 88 IROC A/C clutch diode?
It would be just an ordinary 1A 50V rectifier diode (1N4001). It's job is to short out the inductive kickback from the clutch as it is turned off, in order to protect the ECM. You can of course go with a 3A 1000V diode (1N5408) if it fits, to ensure a long life. It doesn't cost much more.
It's easy to measure if it's shorted out, just pull the plug and measure, it would be less than 1 Ohm (both ways) if in case.
BlueIroc-Z
Jun 9, 2019 03:22 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
mustangman65_79
Aug 11, 2015 03:17 PM
