HEI to small cap dist wiring ???
Old Mar 3, 2008 | 12:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Been 20 yrs since I worked on a remote coil setup and never on a 3rd Gen type
Doing small cap for HSR conversion.
Did a search and came up with some comprehensive info like " " hack up the coil connectors and reroute the tach wire.
Have 4 wire small cap to HEI adapter for ECM control.
Have small cap plug / pigtail (pink / white ) to coil
Original HEI wiring has switched 12V feed ( pink ) and white tacho wires.
Am I correct in assuming that the the two pinks (12V and coil ) go to one side of the coil and the two whites (coil and tach ) to the other?
junkcltr
Aug 2, 2019 11:12 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
