Ignition Module grease
Old Mar 9, 2008 | 09:30 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I know this has been talked about before but I couldn't find what type of grease exactly.
I am swapping modules from one car to another and the person at AZ sold me Dielectric
spark plug protector. This doesn't sound right. Is this stuff ok to use on the bottom of the module?
Also how much do I put on? Is it like the bottom of a cpu, a thin layer?
Shawn
Old Mar 10, 2008 | 01:30 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Ignition Module grease
It's thermal compound, the same stuff you put between your CPU and heatsink on your PC. The ignition module gets pretty hot, and it it uses the distributor base as a heat sink, the thermal compound just helps with heat transfer. It shouldn't take a ton of it, just enough to cover the aluminum part of the ignition module, and fill the gap between that and the distributor. Any computer store should carry thermal compound (might try radio shack too), I'm not sure how well the dielectric grease would work.
Old Mar 10, 2008 | 02:55 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
I went to another AZ and this person gave me something different. He gave me
Dielectric Connector Protector. This still doesnt seem right and I guess I will have
to wonder the aisles until I find it. Thanks for the info on how much to put on.
Shawn
Old Mar 10, 2008 | 05:58 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I doubt Autozone would carry it, but Best Buy, Comp USA, Circuit City, Fry's, etc should. Just ask for 'thermal compound'. The dielectric grease stuff AZ is giving you is to seal electrical connections, like the stuff in your tail light bulb sockets, etc.
Old Mar 10, 2008 | 10:02 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Thanks for the info. I never thought of using CPU thermal paste.
Shawn
Old Mar 11, 2008 | 02:05 AM
Vanilla Sky's Avatar
Avoid any of the "silver" compounds. They tend to either run or are really expensive.
Radioshack has plain-old white goop heatsink compound. I've always had good results with that stuff. Costs like $2 a tube, and one tube is good for quite a few applications. Just dab it on and smear it out. Apply a nice even coat and then screw the ignitor on.
My Honda used to kill ignitors. I'd just toss them on without cleaning the old compound off or applying new compound. After applying fresh Ratshack compound, I've not had a single problem.
Old Mar 11, 2008 | 03:35 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Yeah, I agree that the plain white stuff is fine. I actually read a comparison of different thermal pastes a couple months back, when I was replacing my CPU heat sink. They test different thermal compounds (including the expensive arctic silver stuff), and they all pretty much perform the same.
http://www.dansdata.com/goop.htm
Old Mar 11, 2008 | 08:01 PM
Take that "review" with a grain of salt. He wasn't properly cleaning the heatsink and CPU between applications, and was running the AS3 immediately, with no burn in. AS requires a burn in period.
Anyway, outside of a computer, or maybe higher end audio, I'd just stick with white goop. It does plenty well for automotive applications, and it's cheap.
Old Mar 11, 2008 | 08:21 PM
superbee's Avatar
Car: 89 S10 Blazer
Engine: 355 tbi
Transmission: Built 700R4 w/ 2500 stall
Axle/Gears: 3:73 posi
that dialectric grease should work fine, most modulals are actually shipped with a small pack of it.
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
