help. Battery junction block wires.
Old Mar 24, 2008 | 07:37 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
I need to know where the black with red stripe goes to. I think it might go to be battery but I'm not sure. Mine in my car are cut and I don't have the car running yet. Also I have a cut orange wire on the junction block as well.
Old Mar 24, 2008 | 08:32 PM
AC's Avatar
AC
Car: Used to drive a camaro
Re: help. Battery junction block wires.
year car???
Old Mar 24, 2008 | 11:47 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
89 thanks. Also if anyone could tell me anything about the Alt wiring that would be useful too
Old Mar 25, 2008 | 12:01 AM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
on my 90 tbi alt wire goes to that junction block. then other wires from it feed the fan and two go to the starter motor. ...... But the alternator wire is joined to one of them orange wires
Old Mar 25, 2008 | 12:15 AM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
So there is a wire that only goes from the Alt to the junction box. I know I have cut orange wire. What color is the wire from the battery to junction box
Old Mar 25, 2008 | 12:33 AM
Engine: 4.0 V-6
Not sure of the color I know its black or red cant remember but it goes from the back of the alternator straight to that orange wire on the junction block by the radiator. This wire from back of alternator is maybe 10gauge
opps misread ur post ...... there isnt a wire from that junction block to the battery. other wires go from that junction block to the starter and thats how the charge current reaches the positive cable
I apologize once again LOLOL ... okay this is how mine is ... wire from back of alternator is joined to a orange wire comining off that junction block ..... Then there is a black wire with red stripe that goes straight to the battery cable ..... just checked it.
Old Mar 25, 2008 | 01:04 AM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Thank you so much. So I'll run a wire from the Alt to the junction blocks orange wire. Then I'll rum that black wire so the battery. Thanks again. Oh do you know if that orange wire runs up in the bunch of wires in front the battery. I see a cut wire and I rhink I'd will reach the junction box
Old Mar 25, 2008 | 01:15 AM
Engine: 4.0 V-6
The alt. charge wire I guess could be run directly to the junction block and eliminate the orange wire. but the orange wire that my charge wire goes to is like right by the a/c condensor lines hope that helps.
All the wires that are involved with this junction block are orange. So I doubt even if you hooked it to the wrong orange one it wouldn't charge. I've contemplated bypassing the orange wire since it seems to get pretty hot while car is charging good. But I believe they are fusible links and thats why the charge wire goes to one of them .... This is a 90 TBI firebird v-8 so might be slight diofference in camaro and I'm not sure exactly where the other wires go from this junction block but mine is factory nothing has been cut.
Old Mar 25, 2008 | 01:38 AM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
thanks. This is an 89 firebird that was a tbi but I converted to a tpi with a painless harness. So some wires got cut but now I should be okay with this help. Thanks
Old Mar 25, 2008 | 01:53 AM
Engine: 4.0 V-6
I've seen a 89 firebird and everything at this junction block is the same as my 90 ..... so just put charge wire to one of the orange wires and the black wire with red strip to the positive cable and it will charge fine.
Old Mar 25, 2008 | 08:27 AM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
This is one thing I wish someone produced a replacement for. I have yet to find a good
replacement positive cable that has all the existing factory wiring and doesnt require splicing. Anyone know where I can get one?
Old Mar 30, 2008 | 06:07 PM
Engine: 4.0 V-6
I might have one from a 89 TBI in nice shape
Old Mar 30, 2008 | 07:13 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
How do the wires look near the positive terminal? This is wear most of them
end up getting cut, worn, spliced etc. Does anyone know if a TBI is the same as TPI?
Old Mar 31, 2008 | 03:41 PM
Engine: 4.0 V-6
I have a 1992 camaro TPI positive cable its real nice just need to splice the charge wire from the alternator is all .... pretty easy splice. Cable still has the plug that supplies power to the fans. But yes Its way different then my 89 TBI cable.
Old Mar 31, 2008 | 03:59 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
I'll take that tbi cable. How much sipped to 70124
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
mddaniel
Sep 8, 2015 05:16 PM
andy74
Sep 3, 2015 08:41 AM
