My camaro shuts off!
Old Apr 13, 2008 | 11:18 AM
HeavyMetal350's Avatar
Car: '91 z28
Axle/Gears: 3:73 gears
ok, this is going to be a little vauge, but I wanna ask anyway. I have a 91 camaro and every now and then when i am driving, (doesnt matter if its spirited or not), when i start from a stop, the motor will start to surge and cause the car to buck. sometimes its mild but then sometimes its violent. My mechanic and I have deduced it to be because of a wireing problem located on the PS along the feul injectors. When it is bucking, I have to pull over and I then jiggle the PS Rail wireing. Sometimes it causes the motor to make a weird sound and shut off, while other times it causes the motor to smooth back out. Other than that problem, the motor runs fine, and I try to keep it in good condition. Does anyone know what might be shorting out? or is there possably an obvious solution? (other than just buying a new wireing harness).
Any advice is definetly appreciated...
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Fronzizzle
Aug 17, 2015 02:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
