Intermittent blinker problem?
Old Apr 14, 2008 | 11:25 AM
bolandmi's Avatar
So my right turn signal works fine but my left is a bit messed up. It works from time to time, and when it is working it is slower than the right, when it isn't working, when I set the blinker just stays on and doesn't blink the indicator just stays lit and the turn signal stays lit.
Anyone have any clue what's up with this?
Old Apr 14, 2008 | 01:49 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Intermittent blinker problem?
left staying sold indicats a burnt out bulb. id check that first
Old Apr 14, 2008 | 02:32 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
I just fixed mine this w/e.
I bought new bulbs while I had them open but the problem was just dirty/corroded connections.
take bulbs out, clean socket connections with electrical cleaner (I used a toothbrush) and add some bulb lube (not too much as it is conductive and will bridge the connections causing another short, I did that doh!)
then (this is the more important part) there are three connecting pins in the back of the socket that holds the bulb.
Pull off one at a time and clean those and u'll be all set
PS - Let the cleaner DRY THOROUGHLY before you power it up!
Last edited by British Rich; Apr 14, 2008 at 02:34 PM. Reason: Automerged Doublepost
Old Apr 14, 2008 | 04:15 PM
bolandmi's Avatar
Awesome, thanks for the adivce!
Old Apr 14, 2008 | 08:05 PM
Car: 92 Camaro RS
Axle/Gears: Stock
No worries - if that doesn't fix it THEN you will have to look into "real" wiring problems like bad ground or broken wires, but I doubt it will come to that...
Old Apr 14, 2008 | 08:13 PM
bolandmi's Avatar
Yeah, stupid me turned out it just was a bulb needed replacement. lol
Old Feb 12, 2014 | 06:48 PM
Curlyfireman's Avatar
Car: 87 and 88 iroc z's
Engine: 305 TBI
What kind of cleaner do you use for this? Mine are all pretty gummed up? Also, I located and replaced my hazard flasher, but is there a separate blinker flasher that should be replaced and if so, where would it be located?
Old Nov 11, 2023 | 10:44 AM
sep945366's Avatar
Car: 1984 Z28 5.0
Engine: 305 Small Block
I know this is an old post, but I recently replaced my tail light bulbs and my and my turn signal bulbs. After I did this, my passenger side turn signals stopped flashing. Should I take the bulbs out and clean like you suggest or do you think it's the flasher relay? The connections didn't look too bad when I replaced the bulbs.
Old Nov 11, 2023 | 10:45 AM
sep945366's Avatar
Car: 1984 Z28 5.0
Old Nov 11, 2023 | 12:17 PM
Probably not the flasher, (there's no "relay") since the same one works both sides. Kinda hard for it to be OK for one side but not the other.
More likely, one of the bulbs on that side isn't in the socket right. Go back and check your work carefully.
Old Nov 12, 2023 | 12:14 PM
sep945366's Avatar
Car: 1984 Z28 5.0
I'll do that. Thank you!
88rscamar0
Sep 23, 2015 09:08 PM
TrevinE
Sep 14, 2015 03:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
