all 4 headlights on at the same time??
Old Apr 15, 2008 | 12:29 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
I have an '86 irocz with '88 wiring and a tilt column from a '91 gta. Ever since i installed the '88 irocz wiring all 4 headlights are on when the lights are on.. Its only supposed to be the outside two for running lamps and the inside two for the brights... The brights indicator is on on the dash. Is there a problem with the wiring? is it my brights switch? Would re-wiring the headlights fix this problem?
Old Apr 16, 2008 | 01:25 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: all 4 headlights on at the same time??
I thought the default was supposed to be only the two outside for running lights and all four for full brights.? If that's what you have then I'd say it's normal and supposed to be that way.
Old Apr 18, 2008 | 03:36 AM
86irocu's Avatar
Car: 1986 Iroc-Z
No.. When the lights are on normally with no brights the outside lights are on and the brights are on but dim. they shouldnt be on at all. Thats my problem. I cant figure it out in the wiring. I'm begining to think it is the brights switch thats on the column.
Old Apr 18, 2008 | 06:43 PM
Ah.. Could it be that one harness was made for H4 and the other for sealed beam? I cannot imagine how the column & switch could produce such a fault. I'm sure it lies in the lamp socket configuration. A common fault that produces this effect is the lack of ground to the lamps.
Old Apr 18, 2008 | 07:03 PM
86irocu's Avatar
Car: 1986 Iroc-Z
I triple checked the grounds. i wired my gta column for the camaro wiring harness.
Old Apr 25, 2008 | 01:01 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
OK, cool. So the outside ones are the lows, and the inside ones are the highs.
Right on.
Old Apr 25, 2008 | 01:42 AM
What u gettin at dude..?
Old Apr 25, 2008 | 11:40 AM
86irocu's Avatar
Car: 1986 Iroc-Z
idk what hes gettin at.. all i know is that this isnt how the lights are supposed to be.
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
