91 rs tach dead
Old Apr 18, 2008 | 05:49 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
91 rs tach dead
have a 91 RS. Tach was dead (needle stays all the way left, doesn't move), so i bought an z28 instrument cluster with 145 speedo from Hawks and installed it. Tach is still dead and I am almost 100% confident that the tach in this cluster was good. I need help with further trouble shooting.
I found the connector on the back of the distributor that goes to the tach and I pulled it, blew compressed air in it and reseated it. tach still dead
What is the next step to troubleshoot it? Thanks
Old Apr 18, 2008 | 06:29 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: 91 rs tach dead
Next step would be to find out whether you are getting tachometer pulses to the white wire in the cluster (pin #7 on connector C1).
That will tell you whether the tachometer is bad or the wiring needs attention.
Hope this helps.
Lou
Old Apr 19, 2008 | 09:40 AM
Engine: 350 TBI
Re: 91 rs tach dead
Thats good info. Which connector is C1? I assume it is the one on the right as you look at the dash, that is, the on on the right side of the cluster, behind the tach? And where do I start counting to determine pin #7? top or bottom? Left or Right?
So to test it, should I just put one meter lead on the pin and one to ground? What am I looking for, voltage? Thanks
Old Apr 19, 2008 | 09:44 AM
BigBadLou's Avatar
Engine: TPI
Re: 91 rs tach dead
You're looking for a 12V pulsed signal, something like 5% duty cycle. It would be hard without a scope. Or if you have access to a function generator, you can try that instead and generate a pulsed signal on the white wire behind the tach.
Lou
Old Apr 19, 2008 | 09:57 AM
Engine: 350 TBI
Re: 91 rs tach dead
Wow, thats great stuff. Mostly over my head, but some guys at work might be able to help me.
So those schematics represent the male connectors in the dash that you seat the cluster onto, right? Thanks again.
Old Apr 19, 2008 | 10:24 AM
BigBadLou's Avatar
Engine: TPI
Re: 91 rs tach dead
Looking at the diagram, the view is from the BACK, i.e. as if you're looking at the cluster when it's removed from the dash. Note the "passenger side" and "driver side" designation under C1 and C2.
Lou
Old Apr 19, 2008 | 11:06 AM
Engine: 350 TBI
Re: 91 rs tach dead
You're right. I didn't look closely enough the first time.
So if I put a multi-meter set to Volts AC across the tach pin and the ground pin, that should at least tell me if I'm getting anything, right, even though I won't be able to tell as much as on a scope?
This is the second tach I've tried so I suspect I'm not getting anything to the tach.
It's raining here so i'll have to wait until tommorrow to try it. Thanks
Old Apr 19, 2008 | 11:23 AM
Engine: 350 TBI
Re: 91 rs tach dead
P.S. This is the first time I've ever messed with electronics so I'm pretty clueless aout how to test things and such.
$750 L98
Feb 1, 2025 02:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Eric-86sc
Sep 28, 2015 11:37 AM
raymondandretti
Sep 27, 2015 06:43 PM
andy74
Sep 3, 2015 08:41 AM
