Radio clock always on?
Car: 87 Z-28, 305, 4bbl, automatic ERSS factory radio
Question: The clock on my radio stays on even when you remove the key. I don't drive the car much, so I can't remember if that's normal or not. Have an issue with battery drain.
Car: check
Engine: check
Transmission: check
Re: Radio clock always on?
I don't believe that the clock on the radio should stay on. Of all of the GM vehicles through here none do this. Although later year models you can push the on/off-volume **** and get the time. After a few seconds it turns back off.
If the radio fuse doesn't power anything required, pull the fuse and see if the drain goes away.
RBob.
RBob.
Eric-86sc
Feb 25, 2016 09:02 PM
Gunner242
Dec 25, 2015 04:49 PM
