signal lights work with lights off but not when headlights are on
Old Apr 28, 2008 | 12:29 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey guys im haveing an odd problem with my lights... my signal lights work fine when the headlights are off but will not flash when the headlights are turned on they just stick on eather side you try...what should i look for first... than for the help in advanced guys...
Old Apr 28, 2008 | 06:49 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: signal lights work with lights off but not when headlights are on
Check for a bad/broken ground wire. Headlight(s) is grounding through your signal lights. To test, run a temp ground wire to RT side headlight & test signals. If still no good do the same to LT side.
Good Luck
Corkty
Old Apr 28, 2008 | 07:09 PM
z28monster's Avatar
Car: 86 IROC-Z
thanx for the help ill try that out next time the weather is nicer out... this is just my project car as we speak so there is no hurry...
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
