Burnt a mini starter up. Need help
Old May 1, 2008 | 09:40 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
I tried to start up my car and it started smoking. The 3 wires going to the terminal shorted out. I thought i ordered another protourque starter but i ordered the 829100 gear reduction starter. I have 3 heavy red wires going to the big terminal with the battery wire and 1 red wire that was going to the seperate small terminal. The single red wire burnt completely up inside of the starter at he terminal.I can not figure out what the wire that went into the single terminal is for.
I want to be sure i wire it correctely and i do not know which wires go where on this 3 terminal starter. should there be 4 wires besides the battery going to the starter?
Should all 4 of those wires get a fusible link?
thanks
Old Nov 17, 2008 | 12:04 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Burnt a mini starter up. Need help
Bump, I might have the same problem. Wondering if anyone has any insight on this.
gta892000
Aug 11, 2019 11:16 AM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
09ave
Sep 7, 2015 06:03 PM
Formula_88AE
Sep 3, 2015 01:47 PM
