HELP...no power ANYWHERE!!!
Old May 1, 2008 | 07:52 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
ok, so my camaro hadnt been messed with for a couple months after the megashitter cable broke.......i decided to crank it just to see if it still ran....you know, well it started right up and ran for a little while......i reved it and the tack went crazy and the engine shut off, i thought the ground wire was loose, so i tightened becuase it was a little loose..........now when i went to put the cable back on it arcs like im hookin it up backwards (i know its not on backwards) and if you do put it on without getting electricuted i have no dash lights and no power to the starter or coil...........btw the car is carbed with a hei dist and no computer control
it acts like a hot wire is grounding out, but ive checked and cant find anything
that ive messed with thats bare.......it doesnt smoke with the cables on, but the ground wire does get hot........is there some kind of relay that coulda went bad when the ground wire came loose?
all help on this matter is appreciated
Old May 9, 2008 | 03:33 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Re: HELP...no power ANYWHERE!!!
anybody???? still havent figured it out
Old May 9, 2008 | 11:47 PM
tripingeorge3's Avatar
check your wiring oround the started or your distribution block. i would use an ohm meter from your positive wire to ground to find exact where the problem is ,but definetly use the meter it will save a lot of headache
Old May 9, 2008 | 11:50 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
i went out when it got dark to look for some arcing when i put the cables back on the battery.......it arced around the starter.....the main power wire had a small fray spot.....
Old May 10, 2008 | 02:46 AM
there's a start. fix those wires and do what i said before.
Old May 10, 2008 | 01:13 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
thats a start and a finish.........fixed that and it didnt give anymore trouble
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
