Do I still need my computer?
Old May 2, 2008 | 02:20 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I'm wondering if I can remove my computer and its wiring. I'm all carb and the fuel pump has its own circuit. I can't think of anything thats using the computer, just want to make sure.
If I remove the computer, can I get rid of the large wiring from the pass fender to the Y at the motor? Heater is gone too.
I'm just not sure what I need power for, and what I don't.
Also, does anyone know what that module is behind the front bumper? Car never had airbags....
I know the light harness is on the driver side, need to keep that...
Old May 2, 2008 | 04:03 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Re: Do I still need my computer?
do you still have the stock gauges? the 91 Speedos used Vss which needs the computer to opperate other gauges may need it also
Old May 2, 2008 | 05:27 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Stock speedo, stock voltmeter. The car was tbi, so as I understand it, I have a buffer box which sends a signal right to the speedo, so I may not need the ecm for it?
Old May 2, 2008 | 09:39 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
ive got the same question, i just disconnected my computer a few min ago. turned over fine, gas, volt and oil pressure gauges worked, dont know about the speedo, i didnt go anywhere, ill try tommrw
Old May 3, 2008 | 12:35 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Are you tbi?
Old May 6, 2008 | 05:51 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
it was tbi, removed the tbi and made it carb a few years ago, but left evrything in place. it wasnt until recently that i redid the wiring harness to remove all unnecessary wires. left all the ones to the comp though. havent gone anywhere yet, but as soon as i do, ill let you know
Old May 6, 2008 | 07:14 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Are you using the stock fuel pump wiring? The stock setup uses an oil pressure switch that will turn off the fuel pump if pressure gets low. I'm not sure if it goes through the comp or not.
Us TBI guys may not need our comps for the speedo.
Old May 6, 2008 | 10:03 PM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
went out today, comp disconnected and all the gauges worked fine. speedo, fuel, oil pressure, all worked.
i have my fuel pump hot wired before i start it up to prime it, after it starts i disconnect it and the fuel pressure stays on. the stock oil pressure sending unit is in place. i think i might have to get in there and remove the rest of the wires going to the comp. if i only knew what the are used for.
Old May 6, 2008 | 10:33 PM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
I junked all mine a long time ago just put in a tri pod on the a pilar with the oil water and volt autometer gauges but the stock ones still work too, if your running an electric fuel pump just put it on its own circut, the only diff is I ran my speedo off a cable striaght to the trans so I dont know if youll run into any problems there
Old May 6, 2008 | 10:35 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Cool, next time I drive my car I'll disconnect it. It'll be alive again this week.
Instead of hotwiring it, I would think you could just connect the power wire and pressure switch.
Yea, if I get rid of that computer, theres a good weight in wire I can get rid of.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
