Electrical problem 92 bird? Alternator?
Old May 6, 2008 | 07:50 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Last night my 92 bird ran into a few problems. ie: when i pushed the brake the dash lights would dim, the power locks no longer worked and the pop up lights were screwy. The check engine light was NOT on. Anyone encounter this before, if so your help would be greatly appreciated.
Old May 10, 2008 | 03:32 AM
tripingeorge3's Avatar
Re: Electrical problem 92 bird? Alternator?
batterydying . alternator not charging
Old May 10, 2008 | 06:00 AM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Yea my car has done that before, It turns out my fuse box is gettin alittle wore out. loose terminals on the back side, but I can't remember which fuse. I think it was a red one in the middle of the box. lightly put my finger on it and rocked the fuse side to side and all kinds of stuff would light up or go out.
Old May 12, 2008 | 12:20 PM
Engine: V8 305
i will have a look at that, the problem is not so bad now though. when i push the brake, the gauge will blink along with the headlights. I may have a ground wire loose, i will have a look @ that fusebox, thanks.
db057
Sep 4, 2015 07:57 AM
Navy8125
Aug 22, 2015 07:13 PM
Dialed_In
Aug 20, 2015 01:45 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
