ignition trobble
Old May 13, 2008 | 08:53 AM
jw89camaro's Avatar
Car: 1989 I-Roc Z28
Axle/Gears: 3.45
ignition trobble
my 1989 iroc does not always start but the selnoid opens and closes but the starter does not turn over and i have already replaced the starter with one that works better any ideas guys? other than mw66nova.
Old May 13, 2008 | 12:37 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: ignition trobble
does it make any noises or anything other than the solinoid click?
Old May 13, 2008 | 03:27 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If the solenoid is clicking but not starting the car, there are two possibilities:
1) the contact plate in the solenoid is burned up badly, preventing current flow to the starter motor
2) the solenoid doesn't force the bendix all the way into the flywheel teeth, thus not making contact on the contact plate and not sending current to the starter
If you keep trying to start (turning the key forward) several times in a row, does the starter eventually turn over?
Lou
Old May 13, 2008 | 03:48 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
Lou
...yes...
Old May 13, 2008 | 08:43 PM
BigBadLou's Avatar
Engine: TPI
Welcome to the club of no-starts, then.
I have the exact same problem. I replaced the solenoid and rebuilt the starter but the problem persists. I'm told it's mechanical and the starter needs to be shimmed.
However, I am mainly an electrical guy, I have never shimmed a starter and am not 100% sure how to do it right.
Hold on, you said you replaced the starter. Did it come with a new solenoid too? Also, was it a used starter from Mexiko painted and sold by AutoZone as new?
Hopefully somebody will chime in here soon.
Lou
Old May 15, 2008 | 11:33 PM
jw89camaro's Avatar
Car: 1989 I-Roc Z28
Axle/Gears: 3.45
no its out of a 1989 rs
Old May 15, 2008 | 11:59 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
I had the same problem, changed my ignition switch and my ignition lock cylinder the problem got better, change my startar again and the problem went away..
Old May 16, 2008 | 12:27 AM
wife hates it's Avatar
will try to explain quickley how to shim a starter. loosen starter bolts but leave the long side in. the shim(s) will slide into the space between the starter and the block. you dont ave to remove the starter todo this but still a good idea to kill the battery. listening to the starter after will give you the idea of ow many you need. big growl too tight, tinny too loose, miss and a big zing way too loose. another thing you can try is open the selanoid and turn the brass pin that the pos cable goes to 180deg. this can be done by removing the 2 5/16? nuts on the back of the selenoid, open turn and try that.
lou thanks for your help as soon as i looked at it more closley say exactly what you were trying to explain. work nights myself and will try in am thanks again for your help.
Last edited by wife hates it; May 16, 2008 at 12:31 AM. Reason: Automerged Doublepost
Old May 16, 2008 | 09:49 AM
BigBadLou's Avatar
Engine: TPI
Starter shimming: my starter sounds perfectly healthy, no grinding, no tin sound, just like any other car. It's just the engagement that's not perfect. I might need to tweak the bendix a little, probably file down the gear rear egdes a little more to help it engage better.
Btw, some starter solenoids are sealed, not serviceable. In case you want to replace it, it's good to buy one that can be disassembled and cleaned and serviced.
Lou
Old May 22, 2008 | 01:06 PM
jw89camaro's Avatar
Car: 1989 I-Roc Z28
Axle/Gears: 3.45
thanks guys
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
