fuses
Old May 13, 2008 | 11:31 AM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
Axle/Gears: 3.23 Posi
fuses
My cigarette lighter and dome light don't work and I found blown fuse but every time I put in a new fuse it blows right away I cant find any wires messed up close to that area. Any Suggestions??????????
Old May 13, 2008 | 11:44 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: fuses
Mine was doing the same thing. Take the lighter part out of the cigarette lighter, and set it aside. Put in a new fuse. If it doesn't pop it, you need to replace the whole lighter assembly. (you could probably fiddle with it, clean it and such, but I recommend replacing it) They cost about $6.00 at napa, or somewhere similar.
Old May 15, 2008 | 09:51 AM
Z28 Rida's Avatar
Car: 92' Z28
Engine: 406
Re: fuses
Thanks for the advice. Worked like a charm.
Old May 16, 2008 | 01:08 AM
wife hates it's Avatar
Re: fuses
dont know if youre asmoker or not but one sure fire way to eliminate the prob is to replace that 20 amp fuse with a circuit breaker fuse. solved mine no problem ever again. fuse cools in seconds and resets.
Old May 16, 2008 | 01:30 AM
Johnx's Avatar
Car: 1990 Iroc
Engine: 383
Transmission: th350
Axle/Gears: 4.10
Re: fuses
Guess it's common... If I plug something in mine it bends something inside of it and causes it to short and blow a fuse. But I dont want the cigarette lighter part I want to find something else to plug in it I just haven't found that something yet.
Old Nov 25, 2008 | 02:47 AM
upincomin's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock?? I'm not sure
Re: fuses
You said you kept repacing the fuse. I'm having a hard time figuring out which one is for th cig lighter. I'm assuming it's ACC for accessories. Mine says it's a 20a fuse, I looked and it's a 10a in the 20a spot. Dome light comes on, but no cig lighter. Is this the right one though? Is it the ACC one? I'll change it out tomorrow, thanks.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
AmorgetRS
Sep 28, 2015 09:33 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
