underdash toggle switch?
Old May 25, 2008 | 02:18 PM
86_VA_Z's Avatar
Hello,
I have a 86 Z28. Upon inspecting my wiring yesterday, I found a toggle switch located next to the OBD port mounted onto the center councel. What is this switch used for? There was no way to access it unless the underside of the dash is removed. Thanks.
Kirk
Old May 26, 2008 | 12:56 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: underdash toggle switch?
Hello Kirk welcome to TGO.
That toggle switch is more than likely something added over the years probably a kill switch since there was no factory anti-theft. I would say to trace the wires, I wouldn't recommend switching it until you know what it does, basing this off of past car with wired in kill switch I bumped with my knee and then it wouldn't do anything but flash the lights and I had to start it with a screw driver on the starter to get around.
Or you can always just put the underside of the dash back on and forget about it.
Old May 26, 2008 | 01:00 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Could also be a valet switch for an aftermarket alarm system.
Old May 26, 2008 | 03:25 AM
86_VA_Z's Avatar
Thanks. I was thinking that it was a cut-off switch, and I did flip it to test it out, but nothing.. Finally took the time to trace the wires, and wa-la... nuffin. They terminate into some elec tape..
Hmmm, I think I could think of something to use it for.
Thanks again.
Kirk
Veaceonee
Sep 29, 2016 08:15 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
RacerM
Sep 28, 2015 04:25 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
