HELP! Speedometer wont go above 40!
Old Jun 10, 2008 | 03:58 PM
Bounty600's Avatar
Car: 89 Firebird
Engine: 5.7L V8
Ok, I'm about to take my Firebird from Pennsylvania to Alabama. Yesterday my speedo came uncalibrated, this was my fault. Now I need some help fixing it. Here's what I did to screw this whole thing up.
- I took apart my dash to get to my Speedo because the odometer broke last summer.
- Took off the needle, but when i did my hand slipped and i spun the thing all the way past 140
- Put it back together and the odometer worked for 3/4 mile and died then I noticed my Speedo wouldnt go above 40 mph and I was doing about 80.
Now, here's what you need to know. It's electric, that means there's no cable. This is definitely the Speedometer, NOT the cable. Any suggestions or ideas are much appreciated....especially since I leave in 3 days. Thanks in Advance
Old Jun 11, 2008 | 03:11 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: HELP! Speedometer wont go above 40!
Take needle off, turn key forward to "on", speedo should be at zero. Reinstall needle at zero. Also, try gently prying the needle up with a fork, that should avoid turning it while pulling it off.
Old Jun 11, 2008 | 08:16 PM
im faster's Avatar
haha i have the same EXACT problem thanks ill go try fix it now
Old Jun 11, 2008 | 08:46 PM
im faster's Avatar
ok so there is NO zero... but i think ive got it it took a few times.. but you want it somewhere between the trip reset and 5
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
