Missing Temp Gauge Sender
Old Jul 23, 2008 | 06:59 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
The block I have is a 1974 cmj block from a police impalla. I bought it like this in the camaro. I have looked on the driver side head between plugs 1 and 3. I have found no green wire or any place for a sender to go. Does someone have a pic of one in a car. And what do I do if I don't have a place to put a temp guage sender. I want a temp guage.
I have a 86 Iroc.
Old Jul 27, 2008 | 09:22 AM
IroczInOz's Avatar
Re: Missing Temp Gauge Sender
I have an 86 iroc and my temp gauge sender is located on the passenger side down in between 6 & 8 Plug. Like you say it is a green wire.
If you don't have one in the block you might have to get one installed. But all these blocks should have a temp sender gauge, have not seen any car without a temperature gauge.
Old Jul 27, 2008 | 02:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take out the pipe plug from between the #1 and #3 cylinders. It's there, trust me. If you're using 74 heads (yuck), you'll need to use a pipe bushing to mount a thirdgen temperature sender.
That's the fan switch, not the gauge sender.
Old Jul 27, 2008 | 02:26 PM
Yeah, I am using the 74 head as well, And whats the pipe plug? Is that the coolant drain plug? Cause I was thinking of removing the drain plug on the drivers side head and threading in the temp guage sender.
Old Jul 27, 2008 | 02:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the one. It's not so much a drain as a place to put temperature senders.
Old Jul 27, 2008 | 02:33 PM
The sender will thread right in won't it?
Old Jul 27, 2008 | 02:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not without the pipe bushing.
Old Jul 27, 2008 | 05:34 PM
IroczInOz's Avatar
Funny how if I disconnect that wire the temp gauge inside the cluster stops working.
Far as I know my fan is controlled via the ECM which gets its temperature from the CTS sensor.
Old Jul 27, 2008 | 06:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is your car right hand drive?
Old Jul 27, 2008 | 07:53 PM
IroczInOz's Avatar
Yes it is, but I really doubt they would have changed the sensor over. Brake booster, A/C stuff is still in its original place. But who knows.
dbrochard
Oct 3, 2015 12:43 PM
TrevinE
Sep 14, 2015 03:20 PM
Glowsock
Sep 6, 2015 06:40 AM
85Special
Sep 3, 2015 04:21 PM
