Speedometer questions....
Old Aug 18, 2008 | 02:50 AM
weldmullaly's Avatar
Car: 87' Trans am 89'Trans am 86' Bird
Engine: built 355 SBC 350 TPI 305TPI
Transmission: 700R4 T-5
Axle/Gears: 3.73 Posi
I have a 1986 firebird that came with a 85 mph speedometer. Its electrically driven. I want to put the 140 gauge assembly out of a 1987 trans am GTA in the car. it was also electrically driven. they were both auto cars, however i just did a t-5 swap in my 86. The question is- will the 140 speedo even work? do i need a different buffer box? what VSS should i install in the tranny? i have a couple but one is from a 85 camaro t-5 and the other a 94 firebird t-5. I know one is 2000 pulse and one 4000 pulse but i really dont understand all that jazz... so if someone could tell me what all i need that would be awesome.. thanks!
Old Aug 18, 2008 | 09:44 PM
tdtapp's Avatar
Car: 1987 Trans Am GTA -Black
Engine: 5.7 (350), L98 V8 TPI
Transmission: 700-R4
Axle/Gears: ?
Re: Speedometer questions....
I have an 87 GTA and it has a yellow and purple wire from the VSS on the trans to the yellow buffer box under the dash passenger side.
I don't remember the color wire that connects to #15 on connector 2 that the instrument cluster connects too, but it's for the input of the speedometer from the yellow buffer box. On connector 1 the "G" plug is for the ground side of the speedometer from the buffer box also.
Not sure about the pulse thing. I had to rewire speedometer due to previous owner hacked the harness.
Hope this helps.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
