headlights won't stay on
Car: 88 Trans Am GTA
Transmission: Borg Warner WCT-5
Axle/Gears: 3.45
I have an 88 GTA with a 350 out of a 78 chevy pick up. Needless to say none of the electronics work. I have an aftermarket thermal fan switch that gets its readings from the radiator fins just below the top radiator hose. I guess I need to mention I have the dual fan set up. and when the headlights are on and the car warms up...the fans come on and the headlights go out for about 15 sec and then back on for 15 sec, and so on and so forth
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LIGHT NOT RIGHT
The circuit breaker in the headlight switch is cycling.
It might be a bad breaker or the circuit is drawing too much.
Get an ammeter to verify.
Happy Racing!
-If people drove any slower
they’d be going backwards-
Axle/Gears: 3.45
Re: LIGHT NOT RIGHT
Cool Thanks! That makes alot of sense. where might I find the headlight circuit breaker?
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: headlights won't stay on
Replace the headlight switch, the breaker is an integral part of it.
