VATS removal or bypass???
Old Sep 3, 2008 | 08:26 PM
RSluvr's Avatar
Car: 91RS
Engine: 305 TBI
Axle/Gears: ???
My security light is on and won't go off. I've tried 3 different ignition keys and none of them will work. Is there any way to just totally avoid the VATS system since it seems the module is bad and not the key? I'm assuming the bypasses that are on the market won't fix the problem if it's the module that's shot. I'm not looking to "trick" the system just go around it. Any help and info would be greatly appreciated! Thanks!
Old Sep 5, 2008 | 11:08 PM
draco587's Avatar
Car: 91 RS
Engine: 331 cu in TBI
Transmission: 700r 4
Axle/Gears: 3:42 :1
Re: VATS removal or bypass???
hehe welcome to the club i have the same problem
im an electrician for the rail road and im working on the solve for this i will let you know what i find out
Old Sep 6, 2008 | 09:09 AM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
There are some great articles and posts on this site. Start below and run a few searches.
https://www.thirdgen.org/technical-articles
Corky
Old Sep 7, 2008 | 08:40 PM
draco587's Avatar
Car: 91 RS
Axle/Gears: 3:42 :1
well i had to go with the resistor fix . i found the relay that makes the car crank and bypassed it, but the fuel pump and the ignition are also turned on in the ecm by this system.aparently a prom can fix this or useing a older ecm without the vats system.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
