View Poll Results: Will AWG 7 Be Enough?
Yes, Go for it!
0%
No, you need a bigger one.
100.00%
Voters: 1. You may not vote on this poll
Starter Wire (size?)
Old Oct 4, 2008 | 11:48 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Hi all!
Thinking of adding one extra + cable from the battery to the starter, just for extra juice. And I just bought this cable :
DLS, Power Line LC-OFC Copper Tinned AWG 7 = 10 SQMM
Will that be enoght to handle the juice when cranking ? or do i need a thicker cable ? Also, would this cable be good using as an extra ground to the block ?
been searching around but not found any good thread mentioning wire thickness.
So Will it work well or will it melt ?
Old Oct 10, 2008 | 11:48 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
WIRE YOU SAYING THIS
Have you measured a voltage drop of a half volt or more across the wire you want to jump?
Did you make sure your connections are clean and tite?
Are you running high compression?
If the answer to all three is yes you will benefit from a heavier wire in that location.
But 7-AWG isn’t enuff.
Replace the wire there with one two sizes heavier.
So if you have 2-AWG there now replace it with 0-AWG
Happy Racing!
-If people drove any slower
they’d be going backwards-
Caspar
Jun 19, 2016 11:19 PM
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
