starter will not crank
Old Oct 10, 2008 | 03:45 PM
SCOTT OVERMANN's Avatar
My starter in my 1985 camaro will not crank when turning the key.I applied 12volts to the starter switch lug on the starter and it cranks.It appears to be the neutral safety switch or the ignition switch or the wiring.Does anyone have any other suggestions as what it is or what I should do next to narrow it down......thanks for any suggestions in advance,
Scott Overmann
Old Oct 10, 2008 | 06:07 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: starter will not crank
It could be either the neutral safety switch or ignition switch. Just have to use a volt meter to check for voltages while in the crank position. You can try to jump out the neutral safety switch to see if its bad.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
Cleotiz
Sep 16, 2015 08:02 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
