Right side brake light always on
Old Oct 15, 2008 | 09:58 PM
yanlees496's Avatar
Car: 1984 Camaro Sport, 1985 camaro
Engine: 305 v8, v6
Just as title says, got pulled over for it so now i have to fix it. it works fine when the headlights are off but when i turn them on the right brake light is always on. Any ideas?
Old Oct 16, 2008 | 08:50 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Right side brake light always on
I'd check the bulb first. One of the most common causes is that someone stuck the wrong bulb in there (single-filament vs dual-filament).
Another reason could be corrosion (likely in PA).
A few questions, though:
1) Do both brake lights work fine without lights on?
2) Does the right brake light light up with parking lights on or only headlights on?
3) What happens when you hit the brake with the headlights on?
Lou
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
