Wiper switch dissasembly/repair
Old Oct 17, 2008 | 12:51 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
After a month of tracing wires on the weekend and reaching dead ends, I have discovered that my wiper switch in the column is where my problem lies. I have a switch from a parts car, and the electrical part of it is good, but the lever is broken.
So I need to make one good switch out of two bad ones. Here are pics of the two parts I need to take apart and put back together:
Pics from E-bay and Autozone, not my actual parts (these are identical though)
I just don't want to pull mine apart and break something. Has anyone done this before, how do you separate the two?
Old Oct 17, 2008 | 03:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Wiper switch dissasembly/repair
Pull the turn signal stalk out of the switch (all the signal stalk does is actuate the actual switching parts within the column with a set of levers). You will have to disassemble the upper half of your steering column down to the tilt assembly to get the switch out.
Old Oct 17, 2008 | 10:14 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
I can get down in the column to the switch in a few minutes, that is not a big deal.
Is there a trick to getting it out though? How does it twist out, I felt like I was going to break it when I tried to twist it.
Old Oct 18, 2008 | 03:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The turn signal stalk merely pulls straight out of the hole in the wiper switch. Twisting it WILL break it...
Old Oct 24, 2008 | 10:31 PM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
Okay, I was able to get it apart. I will be taking my column apart tomorrow to try and get this all working. Thanks for your help.
Old Oct 25, 2008 | 07:08 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
what exactly isn't working? i'm having a wiper problem too and i replaced the switch, lever, motor (3 times) and the motor cover (3 different ones). mine get out of park, and go back to park over and over. let me know your results
Old Feb 21, 2015 | 02:31 PM
iroczguy86's Avatar
what dud youall come up with in the wipers jumping up and down< in and out of the park position?? im having the same issues
Old Feb 22, 2015 | 12:16 AM
85IrocZ-28's Avatar
Car: 1985 Iroc Z-28
My switch was bad in the column.
I have to deal with this again though, the electronics in the cover over the motor are bad and I need to replace the electronic unit. I haven't driven the Camaro since 2009, but I working on the brakes now and will be driving it on the weekends this summer.
Old Feb 22, 2015 | 02:44 PM
iroczguy86's Avatar
hey maverick.. i have an issue with my wiper motor switch in the column, but i dont have tilt wheel.. i have the column torn down to the steering housing cover where i can see the switch , i see it is on some type of pivot. i thought the headlight dimmer rod was holding it in so i loosened that but the switch wont come out.. any tips?? (i do not have tilt whel)
Old Feb 22, 2015 | 03:31 PM
Joe Tag's Avatar
I had the same issue with the wipers jumping in and out of park. I can pretty well guarantee you it isn't the switch. I replaced the motor and cover both and it solved it. I think it was a bad contact between the park switch and the cover because it fell off when I opened it up.
Old Mar 12, 2015 | 09:57 PM
Metalizer's Avatar
My wipers are constantly on due to the fact the previous order snapped the turn signal stalk off and busted the wiper switch. Guess I'll be replacing the turn signal and wiper switch just to make sure everything working right.
wigmobile
Feb 26, 2025 02:56 PM
Veaceonee
Sep 29, 2016 08:15 PM
Randomtask2
Sep 10, 2015 08:37 AM
adelane
Sep 9, 2015 08:51 PM
scottmoyer
Sep 7, 2015 07:06 PM
