Random start problem.
Old Oct 25, 2008 | 08:22 PM
pimpflea's Avatar
Car: 1990 IROC-Z Coupe
Engine: 383
I'm having intermittent problems starting my Camaro. I have an MSD 6AL and Blaster Coil. I'm pretty sure it's a spark problem, as I am reading no voltage at the coil when cranking.
What would you guys recommend? Bypass the MSD and see what happens - is this a pretty straight forward thing to do?
Cheers
Old Oct 26, 2008 | 07:50 PM
pimpflea's Avatar
Engine: 383
Re: Random start problem.
OK, I figured out how to bypass the MSD and it still does not want to start. Am I correct in thinking the inputs to the coil come from a module on the distributor? If so, is it likely this unit is corroded & failing? I did have to previously replace my distributor rotor a few years back because it was corroded.
Old Oct 26, 2008 | 08:48 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
not 100% on that one but i think no, if i were you the first thing i would check is the rotor to see if it was corroded
Old Oct 26, 2008 | 08:52 PM
pimpflea's Avatar
Engine: 383
Alright, easy enough to check the dist cap and rotor I guess, so I will give that a look tonight. I have plugged a a spark plug into the coil and held it against the block and got no spark. I am sure the firing order is correct, but yeah, no spark. When it was running it was running fine.
Old Oct 27, 2008 | 05:42 PM
Brennan's Avatar
if it was running fine then just died it sounds to me like a dist problem or a cracked coil my buddy had a blazer that just died one day turned out it was a cracked coil
Old Oct 27, 2008 | 07:44 PM
pimpflea's Avatar
Engine: 383
Well the weird thing is I am still able to start it on occasion. I was able to start it last night but it was running like absolute crap, would die if revs dropped below 1500. So I uploaded an older bin (super aujp 3) and was able to get it to idle at 900 no worries after it warmed up.
I went and tried to start it this morning and it turned over for ages then fired up (just before I was about to give up) and idled fine.
Do you think it's still worth checking the distributor?
Old Oct 27, 2008 | 07:47 PM
Brennan's Avatar
i would anyway just to be sure and its not hard to check it
Old Oct 27, 2008 | 08:56 PM
pimpflea's Avatar
Engine: 383
Cheers mate I will check it out and let you know. I appreciate the help by the way, thanks heaps!
Old Oct 27, 2008 | 08:58 PM
Brennan's Avatar
no prob man
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 26, 2015 04:59 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
mustangman65_79
Aug 8, 2015 12:07 PM
Sherpajames
Aug 7, 2015 06:56 PM
