Wierd fan....
Old Oct 27, 2008 | 08:40 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Wierd fan....
Ok until about a week ago everything works great on my car... Its a single fan and i use the old turn the ac "on" so the fan turns on. (move the switch so that the ac is "on" even though its not, my ac is all gone... basically a switch for the fan. ok so now when i turn on my fan when i'm driving the tach jumps to 0 and the car runs erractically for about 5 secs.... (almost stalling) and if i turn the switch back off while it does that its fine, the problem stops instantly.... if i start the car with the fan on already the car won't rev up right, it runs like crap up top... the car is fine without the fan on. as soon as the fan is turned on it runs like crap. it only started this about a week ago... i have a new alternator and battery installed.... (Like a month ago new) any ideas? Thanks
Old Nov 1, 2008 | 11:47 AM
v10viper04's Avatar
Engine: LT1, L99
Re: Wierd fan....
and now it does it when i have my heater fan on full, anyone have any ideas?
Old Nov 5, 2008 | 04:17 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Re: Wierd fan....
Do you still have the compressor? If so, maybe its dragging when you try to turn it on. If you have it try unplugging it.
Old Nov 5, 2008 | 10:40 AM
v10viper04's Avatar
Engine: LT1, L99
Re: Wierd fan....
Compressor is gone.... i was told a bad ground somewhere...
Old Nov 5, 2008 | 01:04 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Re: Wierd fan....
Check for a short in the A/C wiring and check those fusible links at the starter.
Old Nov 5, 2008 | 01:26 PM
Car: '91 RS Camaro
Engine: 5.0 TBI
Axle/Gears: 3.08
Re: Wierd fan....
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
andy74
Sep 3, 2015 08:41 AM
Apeiron
Carburetors
Oct 18, 2001 04:54 AM
gruveb
Sep 29, 2001 03:06 PM
