key buzzer wont go off
Old Oct 31, 2008 | 06:58 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
well i thought the speedometer swap out would go easily today but i failed miserably. replaced old speedo with a broken needle to break the needle off the replacement. after all is said and done i put the keys in the ignition and the key buzzer never goes off unless i really push the keys in hard. i start the car and the usual buzzer goes off but wont stop.. i removed the fuse that controls the buzzer but the brake lights also share the same fuse so that wont work. i removed the steering wheel so i could put the speedo cluster back in after struggling with trying to force it in and out past the steering wheel. ok im lost and need help if anyone knows how to fix this buzzing or to elminate the switch all together let me know i really appreciate it
Old Nov 1, 2008 | 09:27 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Re: key buzzer wont go off
i just took my buzzer out a couple weeks ago...its above your right knee when your sittin in the drivers seat. pull that panel off. its the size of a pack of cigs. my car is a 89 rs...so it should be the same
Old Nov 1, 2008 | 05:26 PM
Car: 87 Camaro
Engine: 5.7 350 TPI
thanks all set now
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
