Starter ground
Old Nov 3, 2008 | 06:29 PM
jbates346's Avatar
Starter ground
Does anybody know where the hell the starter is grounded to the body at. I can't find it in my chilton book. I got a '88 IROC 305 TPI.
Old Nov 3, 2008 | 06:35 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: Starter ground
i just got over this problem with my 84 mine had a black metal bracket that went from the starter and mounted to the passengers side of the block i couldnt get it to line up after a new starter so i just used and old battery cable and ran it from the post on the starter and grounded to a bolt on the frame works fine so far.
Old Nov 3, 2008 | 06:38 PM
jbates346's Avatar
Re: Starter ground
Hmmm.........I thinking thats theres a grounding problem there. Hopefully its just loose and i can tighten it, if not i'll have to adapt your system. Thanks black.
Old Nov 3, 2008 | 07:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Starter ground
the starter is bolted to the ground, the block!
There should be a grounding strap from the passengerside head to the firewall, and the negative form the battery should be bolted to the block somewhere.
Old Nov 3, 2008 | 07:26 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Starter ground
That's just a bracket to help hold the starter in place........... Not needed and often missing.
Old Nov 3, 2008 | 07:30 PM
Engine: L69 H.O
Re: Starter ground
hmmmm well the starter worked without the ground strap but it just randomly stopped one day i used the old battery cable and havent had a problem since
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
sahlomonic
Sep 20, 2015 07:15 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
