H4, H1...I'm confused!
Old Nov 13, 2008 | 07:44 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
which bulbs do we need in a HID set-up...I'm confused as to the naming of these bulbs! What's the difference..H4, H6, H1......what do I need to get? I see all sorts of descriptions for the HID, but nothing about the bulb types! Help.....
Old Nov 13, 2008 | 07:59 PM
AmorgetRS's Avatar
Re: H4, H1...I'm confused!
HIDs are not H anything, technically. HIDs are D2S and D2R. They are just differnt styles of bulbs, basically. Differnt mounts, differnt plugs, etc.
If you want to do a HID retrofit you need to buy a set of non-sealed lenses and then buy a HID "retrofit" kit that matches the bulb types that the non-sealed lenses have.
Old Nov 13, 2008 | 09:17 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Usually the housings take H4 bulbs, but some use an H1 for high beams.
Old Nov 14, 2008 | 10:59 AM
wdigitog's Avatar
I got these H4's but they have a half-shield in them..how does this work? It seems that the shield would block the light from one side.....I think I have the wrong bulbs...
Old Nov 14, 2008 | 01:27 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
That is an H4 bulb. The sheild does block light, but that's what it's supposed to do. If you look at a normal H4 bulb, inside right by the low beam filament is a sheild to cut down the amount of light bouncing off the lower part of the housing and being thrown upwards that blinds people. Usually those sheilds are removable if you want to see what happens without it.
Old Nov 14, 2008 | 01:57 PM
wdigitog's Avatar
Thanks for the explanation! Well then, I'll put these in and see what happens.....
Old Nov 14, 2008 | 07:09 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
The shield moves to allow different light patterns for the Hi and Low beam, it needs to be there.
Old Nov 15, 2008 | 06:48 AM
Bowtiebruiser's Avatar
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I have a black set in my car how do you move the sheild?
Old Nov 15, 2008 | 08:01 AM
wdigitog's Avatar
Along these same lines.....does one just make a harness to wire the ballasts to the camaro headlight plug? Or does someone make a harness?
Old Nov 15, 2008 | 08:50 AM
krisb410's Avatar
My kit came with a harness, the sheild moves automaticly when you turn the Hi beams on or off. Contact where you got your kit and ask them if they have the correct harness for your kit.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
