Tach issue 91 Z
Old Nov 22, 2008 | 04:44 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Tach issue 91 Z
When i bought the car the tach wasnt working, well today i checked it out and found that it was a bad pin behind the cluster. So now its working but idling its reading about 3,000 rpms. Im not sure if someone put a v6 cluster in or what. And I know the tach signal is correct because i checked it with my multimeter and its reading about 1000 rpms idling. Im going to be doing an lsx swap over the winter, my question is should i even mess with the tach with the tpi in it now or just wait until i do the lsx? Im just afraid that the tach might be innacurate internally and if i dont get it straightened out now its never gonna be correct.
Old Nov 24, 2008 | 09:24 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Tach issue 91 Z
Howdy,
you sure aren't the first one with a bad Chevy tachometer. (Thank you, GM!)
Joint the club, there are thousands of us!
Fortunatelly, there is a way to fix it, without having to buy the whole cluster: https://www.thirdgen.org/forums/elec...meter-fix.html
If you're not comfortable with fixing it, PM me and I can do it for ya.
Hope this helps.
Lou
Old Dec 18, 2008 | 10:18 PM
z28fever's Avatar
Re: Tach issue 91 Z
wrong thread
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
