Factory fog light wiring question.....
Car: Faster
Engine: Than
Transmission: You!
On a 90-92 F-body, is the wiring for the fog lights integrated into the main engine bay harness or is it part of the body harness?
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: Factory fog light wiring question.....
it is on the forword lamp harness that comes off the bulkhead connector on driver side of the car
Car: Faster
Engine: Than
Transmission: You!
The main engine harness also plugs in there though.... Which part of the 2 piece bulk head (engine or body) harness side?
engine side if you look at the connector it comes apart
Car: Faster
Engine: Than
Transmission: You!
I know that it's a 2 part connector at the firewall on the driverside. So if I'm just looking for a new engine harness, I need to locate one with fog lights?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You can find the Fog light wires by reviewing the 1991 C100 diagrams I posted in this forum a while back. I'm pretty sure that all Camaros from 88 -92used the same pin for the fog lights thru those years. ( The fog lights used an independant harness before that. )
https://www.thirdgen.org/forums/elec...body-92-z.html
no the harness is seperate you can take the bulkhead connector apart it is two seperate connectors one for the engine and the forward lamp harness
