gauge help
Old Dec 10, 2008 | 07:49 AM
formula's Avatar
Car: 89 GTA
Engine: 406
Transmission: 700 R4
gauge help
I just picked up a set of 140mph and the higher reading tach. I have an 88 T/A and put them in. I had the 120mph and lower reading tach, will they still read right or are they going to be off.
Old Dec 10, 2008 | 08:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: gauge help
If your car is a V8, the new cluster should work fine.
JamesC
Old Dec 10, 2008 | 11:03 AM
formula's Avatar
Car: 89 GTA
Engine: 406
Re: gauge help
Its a V8, Thanks for the help
Old Dec 10, 2008 | 02:38 PM
formula's Avatar
Car: 89 GTA
Engine: 406
Re: gauge help
Got another problem, the gauges do not read right. The speedometer goes in and out and the tach just reads real slow. They worked alright with the old gauges so I guess it is just the gauges??
Old Dec 10, 2008 | 02:51 PM
JamesC's Avatar
Re: gauge help
Make sure the cluster is well seated.
JamesC
Old Dec 15, 2008 | 03:37 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: gauge help
Does your car have a speedo cable? I know the spring on the speedo itself is calibrated for whatever background the gauge has (120, 140, etc). If you have a V6 and are using a V8 tach, it will read too low.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
