AC/Heater Controller
Old Dec 22, 2008 | 07:22 AM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
The car is a 88 GTA with digital instrumentation, the blower is not blowing. When I push the button for whatever setting (ex. htr/def) the orange light shows the setting but for the fan control there is no light (ex. low/high). What is the possible problem or where should I start?
Old Jun 19, 2009 | 12:13 AM
KC88GTA's Avatar
Car: F- Body 1988-GTA 5.7 Litre TPI
Engine: 350-TPI L98
Transmission: 4 speed auto Overdrive
Axle/Gears: 3.27:1 rear gears
Re: AC/Heater Controller
Check Blower motor 1st, pop hood, unplug blower hot wire, check it for 12v+ when on, with wire still unpluged, apply 12v+ from battery directly to motor, if it runs it is not the motor brushes. Usually on older cars brushes go out on electric motors & need replaced, I had to do my 88 recently, hope this helps.
PS I am looking for Ac/Heater controls [push button digital] if you have or know someone who does please let me know.
Old Jun 20, 2009 | 03:50 PM
smash attack's Avatar
Car: 1988 GTA
Engine: 5.7 TPI
I have an 88 GTA with the digital control also... trying to figure out why the HIGH setting does not work now that the AC is repaired... it will not blow on high or low but it will on the setting in between. Does my AC control need to be replaced or what else could it be ?
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
