Confused
Old Jan 6, 2009 | 01:38 PM
bos's Avatar
bos
Confused
I recently purchased a 1988 camaro and was told it had a 350 vortec in it. I then run the vin number and it came back as a 2.8 liter v6. There is a v8 in it but I'm not sure if it's a 305 or a 350. Can someone please help me with identifying what motor I have in my car? Also will the ecm for a 2.8 match the ecm for a v8? Need help pronto in WV. Thanks!
Old Jan 6, 2009 | 02:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
INSTANT V8. JUST ADD 2 CYLINDERS
Look at the block.
The block has an engine identification number.
It’s just below the right cylinder head, to the rear of the timing cover.
Then get a friend at a dealership to look it up.
There are differences in the ECM but we don’t have the details here.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Jan 6, 2009 | 11:52 PM
bos's Avatar
bos
Re: INSTANT V8. JUST ADD 2 CYLINDERS
thanks
Old Jan 7, 2009 | 02:41 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Here's a couple of suffix code lists. I don't know if they are 100% all inclusive... I think I tried to look up my block which was ended up being out of an '89 Blazer, and they didn't have it... But, who knows, it's probably worth a quick check:And, here's a pretty clear picture of the location where you will find the suffix code.
Hope that helps. Good luck.
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
